Old 03-12-2017, 07:16 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Originally Posted by strictlypersonl View Post
You can relocate the pins that do the cancelling:
1. Remove the steering wheel.
2. Remove the nut and steering wheel hub
3. There are two roll pins on the backside of the hub that trip the cancelling mechanism. Remove them.
4. Drill two new holes 90 degrees from the original location and install the pins there.
Consequently, when things are put back together, the cancelling pins will be at the top and bottom of the hub. It will take more rotation for the cancelling to take place.
Will do, sounds like a good plan
