|    Not Ranked
 To check the output of the alternator use a volt meter.
 Check the voltage before you start the motor at the battery. Should read about 12 -12.5 v.
 Then start the motor and check the voltage at the battery. It should read more. 13-14 volts.
				__________________''Life's tough.....it's even tougher if you're stupid.''  ~ John Wayne
