Originally Posted by jolsen42
Hey Kim, Yes it is the Fast ignition system we used. The ignition box #306425, their coil #308250 and their dual sync distributor #305007 because they are designed to work together, and it does flawlessly. Below is the correct distributor if you are going with a small block ford(260-289-302) They have a tremendous tech staff, very helpful. If you can, talk to Chris Ryan. He is the best!
Regards, John O
Dual-Sync Billet Distributor, Small Block Ford 289, 302, 5.0 Fuelairspark.com
Thanks John! Speed master is offering a complete kit but when I looked at the components I saw their distributor did not have have timing control, really just a cheap Chinese distributor. I'm thinking of doing what you did and use a complete Fast component system, worth the extra money in the long run. What fuel pump did you end up running?
Kim
