03-16-2017, 12:00 PM
SK
Hemi Heads for SBF
Specs: - Bolts on to any 289/302/351w and 351c engine blocks
- Accepts any existing Windsor style intake manifold
- Comes with 2.200”/1.650” Competition Series Stainless Steel valves
- Sets up to 2.050” Installed Height (will accommodate big lift cams)
- Has 62cc combustion chamber
- Uses a Jesel 1.7 ratio shaft mounted rocker system
- Has a Yates C3 exhaust bolt pattern (remote chance of existing C3 headers working)
- Has accessory bolt holes for use with factory Ford accessories
- Uses FelPro 1262R intake gaskets or similar
- Uses FelPro 1433 header gaskets or similar
- Comes with cast aluminum “Hemi style” valve covers
- Uses Flatout valve cover gaskets
- Has .700” thick deck for power adder applications
- Has raised intake ports for more direct flow to the valve
- Flow numbers are 392/intake and 275/exhaust as cast
- Will require distributor extension
- Comes with lifter valley cover
- Uses standard ¾” reach, gasket style spark plugs
- Overall width of 9.5 deck engine is 27.5", 8.2 deck is 26"
Home
$4,995 per set
Brian
