Thank you.
They are still working out some bugs with the ignition. We believe they might be coil related.
It has a Joe Hunt magneto "look" distributor that has a coil installed internally. We are modifying the the Hunt distributor and using an external coil installed behind the dashboard. We will hide the coil wire in polished stainless steel tubing running down the center of the intake.
