Old 03-22-2017, 01:32 PM
C5GTO's Avatar
C5GTO C5GTO is offline
I had a similar symptom on my CRL one time after I had pulled the steering column to work on the brake vacuum booster. After re-assembly, there were spots during the turning of the steering wheel where I could feel some binding but only in spots.
Upon further inspection, I found the the splined end of the steering column shaft was inserted too far into the upper U joint and the shaft contacted the U joint cross at a couple of points while turning. On contact, it became harder to turn, no contact, no binding.
The fix was to loosen the U joint bolt, use a large screw driver to add clearance, and re-tighten the bolt to maintain clearance. No problem at all after that.
I don't know if you have a similar problem but I'd suggest you try to rule out simple things like this before big changes or wholesale replacements.
Thanks,
Joel Heinke (early 90's CRL Cobra)
