Old 03-27-2017, 08:25 AM
REY 427 REY 427 is offline
Cobra Make, Engine: Backdraft Racing, Roush 427R, T56
Originally Posted by cbreez View Post
A clutch will start slipping in higher gears first. Needs replacement but you could probably nurse it a while longer by staying out of high gears...They can fail anytime depending on who's driving, oil leaks, etc.
So if that's the case, any recommendations on what clutch I should replace it with? Not sure where to start. Anything in particular that I should keep in mind since I'm running a T56? I know there are variations of this transmission. I used to run 6 puck ACT clutches on my previous single turbo RX-7s and they held up pretty damn good.
