03-27-2017, 06:53 PM
RI
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
I separated everything
11"Diaphragm Pressure plate Long pattern #360850
11 dual friction disc GM 26 spline reverse hub #260571R
Steel Billet Flywheel #463200 11” 28 Lbs. 0 bal with a 28oz weight bolted on.
PP Bolts 3/8 Gr. 8 Shouldered #1500
Adjustable Pivot ball #16909
Fork Extended length #16922
good customer service
go through Summit it's cheaper but let McLeod answer ALL your questions.
Lou
