Old 03-30-2017, 05:29 AM
LUCKY-13 LUCKY-13 is offline
Registered User
Cobra Make, Engine: SUPERFORMANCE #2611
The top photo rear end is too high, the bottom photos rear end is too low. The ride height on the SPF cars per the owners manual should be set at 26.5-27 inches reguardles of what the tire size is, meaning that if your running a tire that will not slow you to maintain that ride height then your simply not running an appropriate tire for that car. My rear tires are NITTO NT555R Drag Radials in a 325/50-15 and is set at 27 inches. That will be the largest size tire in a 15 inch you can shoe horn under the rears of these cars depending on what car number you have and still maintain the 27 inches. My fronts are Mickey Thompson Sportsman St's in a 255/60-15 and my ride height is set at 26.5. On the front tires you do not want to exceed a 27 inch diameter tire in the 15's beacuse it will rub the backside of the front wheel well. However you can put a 275/50-15 on the front so long as you keep it 27 inches or less. Once again that can vary based on what car number you have, in 2611. I have the Treadwear Goodyear Billboard letters on mine they look awesome!! Avons are great tires but in my opinion I'm running the best tire combo and look that's available in the 15's.
