Resolved the turn signal issue with purchase of a new signal switch. Did some research on the VW forums and most recommend a switch unit made by SWF, German made. It was a little pricey at $180, but works smooth and flawless. Terminal ends need to be changed to match ERA wiring.
ERA on the left SWF on the right
Also resolved the steering shaft play. Upon closer investigation, the nylon bearing had separated from the rubber bushing and was found loose, lower on the shaft. Superglued the bearing back into the bushing. Reassembled, all is good.
