If you have a high volume regular pressure
oil pump and you put a heavy weight
oil in the engine, the pressure relief could be lifted all the time. Then the PRV spring will act like a pressure regulator. So this could be happening. Or the gauge could be defective. Should be pretty easy to connect a test gauge to the engine block and verify your gauge is correct or prove it is full of it.
