Thread: 325 rear tires
Old 04-12-2017, 07:57 AM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
You should contact LUCKY-13 on this board. He recently installed the Nitto 325-50-15's on his car.I have been planning on putting a 325-50-15 on my car since back in August when we tore it down for the overhaul. I have been looking at both the Nitto and the Mickey Thompson. I currently have 17's but I purchased a set of 15" from Vintage Wheels and had them machine 3/8" off the rear wheels to help with the clearance. I expect my car will have the motor back in and be ready for a test drive in the next 60 days. We did a T-56 swap as well as many other modifications and plan to test the car with the same tire/wheel and suspension setup as it has always had. After the initial testing and miles on the new clutch we plan to pull the rear diff for gears, axle up grade and swap to the 15's tire/wheel setup.
