If your gauges remain the same the only issue should be if the wiring will reach the new location. I would think all of the wiring would remain the same and certainly the tach,
oil pressure, speedometer, etc. will not change. I would label everything so that once you disconnect it all you can remember where each connection goes.
Phil
