Old 04-20-2017, 12:09 AM
Locohora Locohora is offline
Default New TKO on Lakewood 15203 T5 Bellhousing
Hello experts,
I think about an upgrade of my engine/gear unit.
The following parts are already available:
- Ford 408w
- RAM Powergrip Clutch 98769 (11", 10-spline, 1.063in.)
- Lakewood Bellhousing 15203 for T5
- RAM 1505 Steel Flywheel 164z
Due to the 11" clutch and the 164z Flywheel I can't use a QT Bellhousing, because they are limited to 10.5" clutches and 157z flywheels.
My Lakewood has only the bolt pattern for the T5 gearbox.
I know the TKO 500 (4615) 10-spline version, which would perfectly fits to my clutch. But I can't find information about the bolt pattern of this TCET-4615.
Is it a replacement gearbox for old, weaker T5 boxes, which means I can it easily mount it against my BH?
Or is there another possibilities to adapt a new TKO on this old Bellhousing?
Many thanks from germay
Alex
