Old 04-20-2017, 10:48 AM
Late Apex Late Apex is offline
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
Default Shift Light info needed.
Im searching for a compact shift light for the column and have found numerous makes but many have bad reviews. I want one that does not require the RPM activated switch which is an additional purchase and more complex install. So far I like the MSD 89631 all in one unit but need your input for those that have a shift light before I buy one. Which model do you have or like? Pros and cons. Thanks
Your ride should not be to get from point to point. It should BE the point!
