rsk289,
Did you find a source for the clips yet?
As you indicated, Finishline sells the emblem cap with clips. Just curious, have you checked with them on their source or recommendation?
I too am about to install my new AC emblem cap with the three clips for the first time. May need such a source too if I break them.
Do you have any guidance on why you think yours broke? Were you pushing straight on, one side firmly then the next, encouraging it, otherwise? Which way were your clips oriented?
When buying mine, I tried my normal Cobra supply sites first, yet the version I was after specifically I was only able to find at Tony Branda. It too came with the three clips, so they may also be able to offer insight into a source for additional clips? I tend to doubt it they way these companies may be sourcing, but may be worth a try.
Interested in your experience. I’ve not yet tried the install mine as I’ve been doing a touch of restoration on my heavily oxidized wheel spokes via polishing, with spectacular result. I must say, a conservative amount of White Diamond polish applied with a wadded tear of Nevr-Dull does wonders and provides good application control, given a few applications. But that’s beside the point!
Best of luck! Thanks, Brent
