Originally Posted by Cobrakiller
Hi Chris, you could use the C6 LS3 Corvette sump to overcome your clearance issue. By raising the engine you will also affect the driveline angles which could cause vibration problems etc. The Corvette sump will give you about 50mm more ground clearance.
thanks CK.. will look into it.. have to drop the sump to swap a cam shortly.
EDIT... dropped the engine back down with the help of gravity..  Been looking around for the C6 sump (or oil pan).. GM parts direct in the US is around $270... rather then $350 (improved performance) to $450. Is the pickup reusable with this sump... any recommendations on local suppliers..?
With thanks
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
