THE BRAINS…
I decided to mount the computer in the back of the glove box upside down. It gave easy access for the harness to the engine. The CD box I mounted on the top of the tunnel under the dash. The wiring was a lot of work. Even though the harness was a plug and play, I ended up cutting and splicing about 80% of the wires(40ish) to the senders and such to shorten them. I also installed a fuel pump cut-off switch under the dash and an inertia cut-off switch in the glove box within reach when I'm belted in
