Originally Posted by Ace23
We did a T-56 swap on my car and going to the taller tires I am going to need more gear than my current 3:31
You really need to take into consideration the gear ratios in your transmission when making a decision on your rear drive gearing. First gear is especially important. I have a 3.27 first gear and am running 3.73 rear end gears. This combination makes first gear borderline useless. I wish I had your 3.31 rear end gears.
Also, when you're making a decision on tire sizes, make sure that the sizes that you choose will allow you to set the car at the ride height you want without creating any rubbing issues. I personally made an error in judgement with my first tire size selection and it was a little costly to remedy that mistake.
Just some food for thought.
Ted
