Your missing brake fluid may be in the vacuum booster. If the master cylinder is leaking past the seals, the fluid gets sucked into the booster chamber and therefor you see no "leaking" fluid. This also destroys the booster and makes the pedal hard.
rick@autoventureusa.net
