Ron,
Red Oxide is a color of a lacquer type primer. This is a 1970's technology product. Use a high build urethane like Duponts 1120s or PPG K36. This product dries by chemical reaction vs. evaporation of solvent. In a nutshell you will get much better results out of these products vs a lacq. type product. After the primer has dried you will need to then spray a guide coat over the primer and block sand until the guide coat dissappears. Call me if you need more clarification. I could go on all night about block sanding.
Shannon
(408)210-1048
