Glen,
Coming along nicely. I doubt that there is a cobra build out there that did not need some adjustments. The hole for the outside leg of the roll bar does look a little tight. Not sure how to open it up for a grommet without either making a poor cut or having to remove the roll bar. given the effort that it took to get the roll bar in, I would suggest that you do without the grommets.
If you have a spare set of grommets, you could try to cut away at the bottom of one and see if there is enough material left to still secure it from the underside. It looks like there might be enough space on the inner leg to place a grommet. Or maybe even cut off the underside of the grommet and use a little RTV around the inner aspect of the grommet to secure it to the roll bar in place?
Looking forward to more updates.
Jim
