Originally Posted by bobcowan
I just heard back from Mechman. Everything they make is actually bigger than than stock. So not helpful here.
The DUI part is a single wire only. So the ECU can't control the output. I don't that's a big deal here. But I expect that it will require a custom bracket. I'll ask them if I can use a standard serpentine belt, though.
Bob,
Mechman only uses stock cases, admittedly aftermarket versions but dimensionally stock. The only way they could make a 'larger' alternator is they sent you a Gen 3 case unit for a Gen 6 case application. If you order the same generation alt case as OEM (In your case Gen 6) then it will not only be the same size it will bolt up where the OEM alt did.
Somebody is misleading you.
Ed
