05-17-2017, 06:50 PM
Cobra Make, Engine: SPF#0760
Sorry for the delay, been real busy of late.
you just take a feed from any full time power supply, (like on ignition switch), add a switch if the flasher you choose to use does not include one, and feed it to the aftermarket flasher units input connection. The output of the flasher unit gets joined to the wiring feeding both the front and rear lighting fixtures parking lights. This setup will operate with the car running or not. Consult your wiring diagrams. Tie in down line of the Reese converter.
Blas
SPFWiringDiagrams@Comcast.net
