Originally Posted by Gaz64
That one would be a lot of effort (time and money) to make mostly correct again.
- top cover from an application with a hot idle compensator
- service choke cap/heater
- no assembly tag (which is often the most valuable part)
Can't tell if it has the unique 1963-64 HP289 brass plug for the spark advance vacuum port that HP289s didn’t use (often missing or badly damaged)
It appears to have been commercially rebuilt in its past. If that is true I would wonder if the accelerator pump cavity filler is there and if the booster clusters are the correct ones.
On the plus side it is from the 1964 model year production time frame.
