Old 05-18-2017, 10:40 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Originally Posted by Luce View Post
There's a couple of them with 460s. That's the same block, right? Fitting the carb under the hood may be a challenge. One of the ones I've seen has an extra large scoop.
Same block, you mean the 385 series is a 460 block too, then yes.
Originally Posted by *13* View Post
I goggled it
Thanks bud, that helps a lot !
Originally Posted by cycleguy55 View Post
I had concerns with how low my pan was to the ground. I had a custom-made pan built by Armando's Racing Oil Pans. It has kick-outs on both sides, three-quarter-length sump and the bottom of the oil pan is 1/4 inch above the frame rails. Pan capacity is in the range of 11 quarts.
I had the kick out pan by Canton, which is 8qts if I remember correctly. Maybe 9 ?
A dry sump system like on the sprint car or like the Vette, would be ok, but expensive. It would have to be a retro-kit.
That's always an option - a custom oil pan could allow you to drop the engine further than you could otherwise. FWIW, my clearance issue is now the bellhousing, not the oil pan.
How much did yours cost ?
Do you have pics ?
Ya, my flywheel cover hit the street one time coming out of a parking lot, and it wasn't that steep.....
Regards,
Kevin
