Nothing more to add here. Shannon and Bob are right on!
We use the Dupont products that Shannon suggested, (definately stay away from any lacquer based products), then we just use a black, red, gray, what ever contrasting spray can paint, and spray a light mist coat over the entire car. This will give you a good guide coat for your block sanding.
One more re-iteration - do NOT touch the body before cleaning it! No sanding, no spraying, just wash it with a good body prep.
The reason for this is the mold release compound that remains on the body when it is pulled from the mold. If you start sanding on it before cleaning you can and will just bury the release agent into the glass.
Paint does not do well covering up wax! Good luck and post some pictures for us if you can!
DV -- We need your help and support! Have you bought your raffle tickets yet? Full TV coverage, 250 plus Cobras, 3 days of rolling fun, it just can't get better! Are you registered?
