Get rid of that clutch
Rjw289 You have a couple of problems, First get rid of the junk,(CENTERFORCE Clutch). I when through 2 trannies with the garbage clutch. Would not shift over 3,000 rpms, wouldn't go into gear when hot. I swapped everything. Found that the weights that slide on the pressure plate, HANG!!!!. Call Bylins and get a twin disc McLeod clutch. Pedal is easy, Holding power is great for a 620 torque/ 525 HP motor had doesn't go over 6,200 rpms. Feed back is also good. I have a fork setup for throw out bearing, ERA setup. I had a Tilton thrown out bearing and the seals leaked a couple of times, went back to basics. I call Centerforce 7 times, got no tech help, was told everything was wrong or bad but their clutch. I finally removed the sliding weights and could shift at 6,000 rpms. I when to a bigger motor and asked Bylkins about a better clutch for a bigger motor with alot more power. Twin Disc is the way to go. Easy to setup, been racing 5 years and no problems. Worth the extra money. You wouldn't be sorry to buy this.
Richmond trannies, You didn't say which one you have. When they get real hot they bind or will not shift. You will find that replacing that clutch will fix 98% of your problems. The side not is to install a bildge fan and run it down the trans tunnel. Alot of heat builds up under there. I have a 4" with a hose. The other thing is the torque or HP of the motor. Some of the trannies are good for only 450/450 power. The Superstreet 5 speed is good for 600/600. The constant load on it over time could cause a shifting issue. The other option is to installed a trans cooler. Use the drain and fill holes for inlet and outlet of the system. 12 volt pump and a rail cooler mounted to the frame rail. Relay for the pump and switch. 20 amp fuse. Just make sure your charging system will handle the extra 10-15 amp load with this running. Good Luck Rick L
