Originally Posted by joyridin'
In order to do that, you would literally have to cut out the whole trunk area. It is resting on the floor of the trunk that sits about 8" below the frame rails.
Not a small task by any means.
For a useful trunk, not nearly as much work as you might imagine. Cut out the trunk, mount an underfloor tank below the trunk, bend a few aluminum panels to fit over the trunk framework, rivet in place. Then run a filler hose from the cap to the tank filler tube.
Bob
