  #43 (permalink)
Old 06-01-2017, 09:45 AM
nniets's Avatar
nniets nniets is offline
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
Originally Posted by Karl Bebout View Post
"It's a flat tapper motor .. Karl???"
Carnut, it was definitely doing some serious "tapping", all the way home from Flagstaff. Ran fine over 2200-2300RPM. The idle was a "little" rough. I guess my tiny engine doesn't need all 8 cylinders.
Karl - we should spruce up your little engine with the hemi heads from the current issue of Reincarnation. 600 horsepower... You could keep up with Mike (any Mike you want).
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
