Old 06-03-2017, 07:35 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Originally Posted by Riverside racer View Post
That was when we switched to Mobil 1 75w140 GL-5 Gear Oil....
Very nice Morris....what was the difference in Temp reading once switched?
Ross
We tested Pennzoil 75w140......Valvoline 75w140.....Redline 75w140.......and Mobil1 75w140, Synthetic gear oil in the diff......
Mobil1 was 25*- 30*degrees cooler then any of the others.....also it was. Very hot day....about 90*degrees......
We run a Quaiffe Differential so gear contact is very important to us....and we also use a cooler and filter on both the diff and trans to control the heat.
Hope that helps.
Morris
