  #21 (permalink)
Old 06-04-2017, 03:14 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by FatBoy View Post
I've cut the filter open and there's absolutely nothing metal in there.
I'd have to reassemble the engine and run it to test the oil pressure, so it makes no sense to me to not replace the oil pump while I have it out.
If, when I've fitted the new pump it still misbehaves, I'll check the pressure with another gauge.
I've spun the pump on the bench with an electric drill and it doesn't sound particularly healthy. There is a definite knock and a tight spot.
Paul
I would have checked the pressure with another gauge first, as mentioned by a few others as well.
