Old 06-06-2017, 04:24 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Default Side Oiler, Little Disapointing Dyno Numbers ?
Found this ad. $12,500.
For sale is a 427 side-oiler with less than 1000 miles on rebuild. This originally came out of a 1969 mustang mach 1. The block has been bored .030 over with no sleeves. The block number is 2J29. Steel Crank that has been turned 10/10. Manley H beam rods. Keith Black Pistons that have been high temp coated. Custom grind Competition billet hydraulic roller camshaft. Gross lift is .540. Crane Cam roller lifters. Cloyes true double roller timing chain. Rebuilt 428 cobra jet heads with high temp coated valves (C80E-6090-N). Harland sharp roller rockers with rare sidewinder intake (C6AE9424J). This motor has been blueprinted and balanced.
On the dyno it put out 480 horsepower.
Regards,
Kevin
