06-11-2017, 03:51 AM
MI
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Originally Posted by pormgb
I had a similar problem on my LS6 swapped Porsche 944, the starter would not turn after the car reached its full temperature then sat for a few minutes, if I drove the car hot then restarted it, it would start right up. Since you are seeing a power drain, power is getting to the starter, it sucking almost all available amps.
My issue was related to the close proximity of my starter to the exhaust headers and the stock starter could not handle the heat, I think it was heat soak why it would not turn once the car sat for a few minutes.
I replaced the stock starter with a high torque gear reduction starter and the problem went away, I also use a high torque starter the 352 in my Cobra.
THanks!
The other possibility I just thought of is the clutch depression switch which only allows the car to start when the clutch is fully depressed. Although it is not located in an area subjected to major heat (if that was the case it would also impact the brake light switch as they are co-located) it is a link in the starter circuit. I will run a jump wire in the event it happens again and I can easy jump the circuit to diagnose if that is causing the problem.
THanks
Jeff
