Old 06-11-2017, 07:25 AM
HI Cobra's Avatar
HI Cobra HI Cobra is offline
I had a similar problem on my Kirkham awhile ago which got to where if
I stopped anywhere, then tried to start it after about 2 minutes, nothing would
happen. It was a heat soak situation with the MSD 6a1 which was mounted on
the passenger side fire wall in the cockpit. I sent it to El Paso for checkup and
aout $36 and 2 weeks later got it back - end of problem. (They replaced some
electrical components that had gone bad on it)
If you have the MSD 6a1 or similar, and find no problems with the starter, you
might want to check it out.
Flip
