A customer brought his Backdraft in to our shop on a flatbed the other day, said he hit a pot-hole hard and then lost mechanical connection between engine and drive wheels.
Once on the rack, did some quick investigation and found broken pin-drive adapter. Not being familiar with Backdraft, where can this adapter be sourced from?
Also found that either the differential is an open unit, or that the limited slip function is non-functioning. Are LS differentials standard with Backdraft?
