Old 05-23-2002, 05:45 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
$.25 more.
This is a straight remove and replace, or it oughta be.
If the oil pump appears to have been damaged, replacement is two bolts. You will have to remove the distributor, and re-install it. For the $30 - $40 for a new pump, it's not a big deal. But you do have to match the pump pickup with the new pan.
There is no reason to pull a main cap off because you wacked a pan and had the good sense to shut the engine down. however, since you have tha pan out, and you're curious, inspect a main and a rod or two for abnormal wear.
On reassembly, use contact adhesive or weatherstrip adhesive on one side of the pan gasket, and non-moly wheel bearing grease on the other. Now, you can drop the pan for inspection and cleaning anytime, and button it back up with the same re-usable gasket.
