Morgy's screwdriver
Morgy,
The screwdriver you acquired is probably very close to the correct one that came with the Cobras. Notice the "FOREIGN" stamped on the shaft.
The screwdrivers in the Cobra tool kits were about 10.5" in length and were stamped "Made in Italy" on the shaft. The handle was European birch with red paint. The same screwdriver was also made stamped "FOREIGN", I suspect later than the "made in Italy" ones that were supplied with the Cobras.
So, you have an almost correct screwdriver if it is 10.5" in length!
