  #24 (permalink)
Old 07-06-2017, 05:13 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by cycleguy55 View Post
Ford Solenoid:
A: Battery
B: Switched battery current when starting
S: Ignition switch 'start' position
I: 12V current for coil for starting (full voltage instead of reduced voltage normally supplied when ballast resistor is used)
Thanks Brian,
I see that now.
That's if he is using a ballast resistor ignition, no mention of that yet.
Gary
