Never had any problems with my TKO600 and Pete Brock used it for the R&T track tests where it was put through its paces. Shifts smooth and fast, no chatter, quiet. In any event, whatever tranny you use, don't pull the engine unless you absolutely have to. Way too much involved for a simply clutch or tranny change unless you have the old welded in tranny cross-member and, if so, cut it out and replace with the BRE removable cross-member so you can change the clutch or tranny without pulling the engine.
