Originally Posted by ACHiPo
No ballast resistor (that I'm aware of). The "S" is connected to the spade lug on the PowerMaster solenoid, the "A" is connected to the "Battery" terminal on the PowerMaster solenoid.
Do you think you need this solenoid now you are using a starter with it's own solenoid?
You could remove this to tidy up the installation, unless you want it for authenticity?
What ignition system are you using?
Gary
