07-07-2017, 05:25 AM
KY
The 46's would be a hotter plug. I usually run the 45's as well with most of my factory head combinations. Autolite does make an "AR" plug in 18mm, but if this is a street engine, you're probably better off with the regular plug.
Post some pictures of a few of your spark plugs and we can tell you if you need a little colder heat range or if the 46's will be fine as a replacement.
