Old 07-08-2017, 08:31 AM
olddog olddog is offline
It is my understanding that solid roller lifters need a lot of oil, and even blocks drilled for hydraulics cannot take long idle times. Solid lifter FE engines rely on oil slinging off of the crank. I agree your problem was not the manufacturer's product quality, therefore you're not going to find another brand that is going to solve the problem.
If you are going to run solid rollers in that block, you have to be prepared to replace them frequently.
Where is Patrick? Now is the time to talk about the virtues of a solid flat tappet cam. You will give up some power, but gain longevity if you use the right oil additives.
