Old 07-11-2017, 12:10 PM
cycleguy55's Avatar
Originally Posted by RockBit View Post
Troy:
I have a medium riser intake (Edelbrock RPM) on my ERA427 SC. I went with the 14" K&N with a drop base as recommended by ERA. With the drop base, the chock and air bleeds hit the underside of the xstream top. I measured the hood clearance carefully and added a 1/2 inch riser between the carb and drop base. It clears. Even though I have a hood scoop, I think it would clear without the scoop. Let me know if you need more info such as part numbers.
Oval or small air cleaners fit up into the scoop, if one's there. 14" round air cleaners typically interfere with the hood itself as they're too wide to fit up into most scoops. If your 14" round AC fits it will almost certainly fit under 66gtk's hood.
Question: How deep is the drop on your AC? They come in different drops, and 66gtk could likely just get one with 1/2" less drop - assuming the sizes are that granular. I just looked at Summit's listings for 14" drop bases, and here's what they have:
Drop (Qty.)
0.156 in. (1)
0.200 in. (1)
0.375 in. (3)
0.875 in. (1)
1.000 in. (1)
1.250 in. (1)
1.375 in. (9)
1.500 in. (3)
1.625 in. (1)
1.750 in. (3)
2.670 in. (1)
https://goo.gl/Jo2Fgm
Brian
