Old 07-17-2017, 06:21 AM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Default Clutch pedal catchy
The last few times I've drive the car the clutch pedal travel seems catchy thru its motion. The clutch engagement point is the same, the engagement feels the same - the clutch doesn't feel like it is slipping, there is no burning smell, the fluid is clear. I flushed the fluid just to be sure. Any thoughts on why the clutch pedal movement would feel this way? It hadn't done this before.
Tilton master cylinder, McLeod hydraulic TOB, McLeod single disk clutch, steel flywheel.
