07-17-2017, 10:15 AM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
Originally Posted by Texasdoc
The last few times I've drive the car the clutch pedal travel seems catchy thru its motion. The clutch engagement point is the same, the engagement feels the same - the clutch doesn't feel like it is slipping, there is no burning smell, the fluid is clear. I flushed the fluid just to be sure. Any thoughts on why the clutch pedal movement would feel this way? It hadn't done this before.
Tilton master cylinder, McLeod hydraulic TOB, McLeod single disk clutch, steel flywheel.
Does it behave the same way if the motor is not running? Have you confirmed that the mechanical (non-hydraulic) elements of clutch activation are operating smoothly?
