ASO544,
Just a thought regarding your comment: "My other concern is I can only check the car when on jack stands and the suspension is full flexed so that may be hiding the problem."
Whether for this issue or future reference, a set or two of RhinoRamps or similar from the parts store can supplement the jack stands with a similar height while keeping the suspension engaged when needed. I went with the heavier duty ones, not for the extra weight bearing capacity, but they're wider to better handle wider tires.
You can check/access engaged suspension with wheels turned at various degrees for clearancing, brake line routing/testing, etc. as well.
Good luck finding your noise issue. Brent
