Old 07-23-2017, 05:50 AM
1795's Avatar
1795 1795 is offline
Originally Posted by ASO544 View Post
I also noticed the two large bolts that you can access from the access plates in the trunk....are those for the rear end mounting?
Those two large bolts are for mounting the differential.
I would agree with the others that you should get the car up n ramp t keep the suspension compressed and check the angle between the tail housing of the transmission and the pinion of the differential.
The problem with getting the car up on a lift so that the suspension is loaded is that you cannot turn the tires and see the driveshaft moving and listen for noises. I was just thinking that maybe if the car was on a dyno you might be able to run it at ow rpms and listen for a noise and possible look for things that may be binding or moving?
Let us know what you find, and good luck.
