Old 07-23-2017, 08:42 AM
Tjd Tjd is offline
Jack up one wheel at a time with the jack under a arm so the wheel off the ground and then turn and shake the wheel to see if there's any play we careful it doesn't fall on you
Do both rear wheels at the same time if you have two jacks or block one side up and hold the other room with the Jack then rotate wheels and listen for noises
Only have to lift it high enough so the wheels not touching the ground
Tom
