  #62 (permalink)
Old 07-26-2017, 04:33 AM
Treeve Treeve is offline
Cobra Make, Engine: Dax
Originally Posted by ICCARS View Post
Hey Treeve,
under the section "Modifications which require brake system assessment" it states in section 18 that ICV's using donor car brakes do not require the use of the ABS system. Does the statement that all ICV's require the use of ABS over ride the prior section 18 detail?
G'day Wil,
Unfortunately, you've misread what it says - it's a lot worse than that.
What is says is:
"ABS and/or EBS from the donor vehicle shall not be used."
This means you can't use the ABS from the donor vehicle, but you still have to have ABS - so you have to get ABS from somewhere else, then get it sorted for your vehicle.
Good luck finding a highway approved aftermarket ABS controller - or completing the full ADR testing as required by the comment at the start of the document.
Treeve
